2000 Chevy Silverado alternator
150,000 MILES • 6 CYL • 2WD • AUTOMATIC
THEDUSTER
Need procedure for removing serpentine belt to remove and replace alternator
Mar 14, 2009 at 4:13 AM
OBXAUTOMEDIC
  • 3,719 POSTS
[quote:ea33aac358="theduster"]Engine Mechanical problem
2000 Chevy Silverado 6 cyl Two Wheel Drive Automatic 150000 miles
Need procedure for removing serpentine belt to remove and replace alternator[/quote:ea33aac358]
Go to the link below find your engine layout. Locate the tensioner assembly on your vehicle. Using either a special tool for loosen tensioner or using a ratchet and socket to loosen tensioner, move tensioner the away from belt. If belt goes around the right side of pulley then loosen by moving it to the left and vise versa.
http://www.2carpros.com/car_repair_information/tec_info/2000/chevrolet/silverado/2000_chevrolet_silverado_drive_belt_routing_diagram.htm
Mar 14, 2009 at 4:20 AM
