2000 Chevy Silverado
145,789 MILES • V8 • 2WD • AUTOMATIC
CPTSQUISHY
i have to turn key 3 or more times to start truck,i have replace fuel filter,changed starter due to going bad,and put injector cleaner in it.it still does the same thing..i am unemployed and can not afford to take it in...
Aug 18, 2010 at 3:08 AM
WRENCHTECH
  • 20,758 POSTS
The first thing you want to do is get hold of a fuel pressure gauge and see what the fuel pressure is when your having this problem. This is a high pressure system and requires a minimum of 55 PSI and fuel pump failures are common.
Aug 18, 2010 at 3:17 AM
