2000 Chevy Silverado
54,000 MILES • V8 • 4WD • AUTOMATIC
BAFFLED454
My 2000 Chevrolet Silverado, 454, is really starting to drive me crazy. It hesitates when you acclerate. Cylinder 3 shows multiple missfires. It idles fine with no problems, and if you ease into the throttle it will rev up pretty well, but starts missing. It goes into lean mode when it should go rich. It has all new injectors fuel pump ignition wires plugs module cap and rotor. The tps seems to be working correctly
no restriction in the exhaust.
Does anyone have a suggestion?
Thanks
Sep 1, 2009 at 2:29 AM
BAFFLED454
update
Mass Airflow sensor fixed problem
Sep 2, 2009 at 8:01 AM
