2000 Chevy Silverado
65,000 MILES • V8 • 4WD • AUTOMATIC
DFLANDERS4
the brakes in my truck go to the floor under heavy pressure. i have no warning lights and my resevoir is full. brakes seem to stop the truck ok but low pedal
Apr 24, 2008 at 12:20 PM
  • 31,937 POSTS
Hi there,
Check fluid level, if low check for any leak, re bleed system if still poor pedal, you may have a faulty master Cly that is by passing, (fluid leaking past internal seals of the master Cly) if this is the case, normally you can test by turning off engine and pump pedal till all vacuum expelled. Pump pedal up till firm and hold light but steady pressure in pedal, if by passing, pedal will slowly sink to floor.
mark (mhpautos)
Apr 24, 2008 at 10:32 PM
