Daytime running lights not working
BOOTD
  • 2005 CHEVROLET SILVERADO
  • 5.3L
  • V8
  • 4WD
  • 235,000 MILES
The daytime running lights do not work. Bulbs are good and the fuses are good.
Sunday, June 29th, 2014 AT 10:48 AM
HMAC300
  • 48,601 POSTS
Check relay under hood as well as fuse if you didn't already check that. switch relay with a like relay.it will be marked on fuse box cover. Here is a guide to help test it and the headlight and DRL wiring diagrams so you can see how the system works:
Sunday, June 29th, 2014 AT 11:08 AM
BOOTD
Wouldn't the fuse blow before the relay went bad?
Sunday, June 29th, 2014 AT 11:18 AM
HMAC300
  • 48,601 POSTS
Not necessarily the relay gets it s' power from another source so when you hit the switch you just activate the relay so it may not be activating or wher eit plugs into fuse box may be corroded.
Sunday, June 29th, 2014 AT 11:21 AM
STEERMAN1724
  • 2004 CHEVROLET SILVERADO
  • 6 CYL
  • MANUAL
  • 44,000 MILES
The Daytime Running Lights will not come on during the day. I have checked all fuses both in the inside and inderhood boxes. The headlights come on both day and night as well as the dash lights stay on and work with the dimmer. I have tried it with the truck parked and the parking brake off as well as driving down the road. What can I do to isolate the problem.
Wednesday, December 18th, 2019 AT 10:42 AM (Merged)
DOCFIXIT
  • 18,828 POSTS
Under hood relay box find DRL relay swap with fog lamp if it works then replace. If no then BCM is suspect it grounds relay when engine is on.
QUAGMIRE86
  • 98 POSTS
Silly question, but did you make sure the DRL bulbs are not burnt out? (At night, the DRL's won't come on. The optical sensor on top of your dash will instruct the BCM to illuminate the Headlamps only. If the DRL bulbs both burn out, and it is daylight, you won't have running lights while in gear). If you have already confirmed the bulbs status, disregard.
STEERMAN1724
Ok if the bulbs were burnt out (which thy arent) and the system was working wouldn't the headlights NOT come on? My headlights are staying on and the non-burnt out daytime running light are not coming on. The dash lights staying on indicates to me that the system is never switching to DRL mode.
GREGHZL
  • V8
  • 44,000 MILES
My dtrl will not come on but my headlights will There on all the time instend of the day time running light. I can turn on and off the headlights from the switch, HELP!
Wednesday, December 18th, 2019 AT 10:43 AM (Merged)
GM4YRS
  • 5 POSTS
On 2000 + silverados, you can push the dome override 3-4 times and you will hear a chime. This will switch your lights off. Repeat this to return to headlights. Read your owners manual for more info. On 99 silverados, this will not work. Also, look on the dash, middle defrostor vent, for a black dome. Make sure a dash mat is not covering that. If covered, the sensor will think it's dark outside.
ROCKWOOD84
  • 103 POSTS
There is a fuse for the drl lights but if the headlights are on the drl won't be if the sensor on the top of the dash is covered up then the lights will stay on.
BABYDOLL33X1
  • 2000 CHEVROLET SILVERADO
  • V8
  • 4WD
  • 152,000 MILES
My daytime running lights will not work. I have changed plug, bulbs and fuse.
MERLIN2021
  • 17,250 POSTS
Probably the DRL(daytime running light relay) Could be one of 2, new or old style, new style is in the underhood fuse block near the radiator as seen below:
https://www.2carpros.com/forum/automotive_pictures/62217_DRL_relay_1.jpg
Old style is in the convenience center on the left side of the firewall. as seen below:
https://www.2carpros.com/forum/automotive_pictures/62217_old_style_DRL_1.jpg
Check out the DRL wiring diagrams (Below). Please let us know what happens.
Cheers
BABYDOLL33X1
Thank you very much, great service! It was the relay.
DEROGA
I have a 2000 Chevy Silverado 5.3L 3 door.
The daytime running lights are not working.
The bulbs are good.
All fuses are good and the relays are good.
All other lights work the way they are supposed to.
What am I missing.
FASCARS
Read your owners manual, I believe you can program your daytime lights to burn or not burn.
CHEVY22
  • 1,375 POSTS
Yes you can program them, I think on the left side of the dash near the headlight switch should be a push button, and if I remember right you hit it three times to turn on or off, but if not there may be another problem, sensor on top of the right speaker
jim
DUMMY#7
I have been looking every where online. I have a 2007 Tahoe and the DRL's are not working. Not bulbs, not fuses. Assume the ambient sensor is working because headlights do come on at dark. Yes, car is on, no emergency brake, etc. Can't seem to find the location of the DRL relay or possible Diode to replace. Any help? Thanks
Thursday, April 23rd, 2020 AT 12:02 PM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 47,536 POSTS
We need to check the DRL relay which is controlled by the BCM. here is a guide to help us and the relay location as well along with the DRL wiring diagrams so you can see how the system works:
Check out the diagrams (below). Please let us know what you find. We are interested to see what it is. If the relay is okay the BCM is probably bad.
Saturday, April 25th, 2020 AT 2:47 PM
