I have water gushing out from the drain tube. Not sure if it is related to the heater core being bad or clogged possibly. Low coolant light comes on, we fill it every 3 days. No water on the inside of the car but a pretty steady leak on the outside. I removed the heat shield on the passenger side to expose the drain tube and the leak is definitely coming from there. No leaking from the heater core hoses.
As a side note I recently hit a deer and had to have a new compressor installed as well as some work to get the fan on the air conditioner to work properly. Could this have possible caused any of the issues or is it a coincidence. The leaking started 1 week after getting the truck back from the shop.
Thanks
Thanks
Aug 24, 2009 at 4:56 PM
