1999 Chevy Silverado Vibration at 60 mph
230,000 MILES • V8 • 4WD • AUTOMATIC
JKBEAUMONT1
  • 13 POSTS
I have a vibration (felt through the steering wheel) that starts a little at 40 mph but is at its worst at 60 mph. I have had the tires checked (they have 12,000 miles on them) and even had the runout (force variation balance) checked and everything with the tires and wheels seems to check out OK. Could this be a suspension issue? Maybe a ball joint? My tire place that checked the balance and runout on the tires and wheels indicated that the upper ball joint on the passenger side was worn and looked as though it needed replacing. Could this be causing the problem? Thanks guys!
Feb 23, 2009 at 1:42 AM
RHALL77
  • 3,361 POSTS
it could be your problem. check your front end for loose parts. also take a look at the drive shaft and see if there is any weights missing off of it. you will be able to tell by the clean metal where a weight use to be
Feb 23, 2009 at 2:09 AM
