1999 Chevy Silverado Starter engages while truck is running
1999 CHEVROLET SILVERADO
176,000 MILES • 6 CYL • 2WD • AUTOMATIC
FICKTODD
I have changed the starter relay and the starter. Still engages while truck is running. Is it the ignition switch?
Feb 12, 2010 at 1:11 PM
DOCFIXIT
  • CAR REPAIR CONTRIBUTOR
  • 18,828 POSTS
Pull small solenoid wire off use test light turn key to start release to run if light stays on then ign switch.
Feb 12, 2010 at 1:59 PM
FICKTODD
I actually got the truck started and put a dmm on the small wire, which I removed, and read 14.33v. Sounds like you were right. Where on the steering column can I find the serial number so I can figure out which switch I will need?
Feb 14, 2010 at 9:13 AM
DOCFIXIT
  • 18,828 POSTS
Ign switch is down on collumn near floor on top two small screws hold it on.
Feb 15, 2010 at 12:07 PM
