1999 Chevy Silverado shocks
1999 CHEVROLET SILVERADO
230,000 MILES • V8 • 4WD • AUTOMATIC
ROD777777
How to repair Broken shock mount on 1999 chevy silverado
Jan 12, 2010 at 12:54 AM
PEAR69
  • CAR REPAIR CONTRIBUTOR
  • 1,482 POSTS
Is it on the front or back? Upper or lower?
Jan 12, 2010 at 1:06 AM
ROD777777
It is the front passenger side and it is on the top where it brock
Jan 12, 2010 at 1:10 AM
PEAR69
  • 1,482 POSTS
You have to weld it. If it is broken right off, then you may want to go to the junk yard and carefully cut a mount off, or you can cut it off and install your own...Anyway you do it you must weld..If you have to weld anything to the frame, you better know what you are doing and have the frame on a frame machine (or something similar). Welding on any frame will cause warpage from the heat. If you don't know what you are doing, it is best to go to an ASE certified mechanic..
Jan 12, 2010 at 2:56 AM
