1999 Chevy Silverado rear wheel bearing
CHRIS LYND
Drive Train Axles Bearings problem
1999 Chevy Silverado V8 Two Wheel Drive Automatic
inf on changing rear wheel bearing. emer. brake take off and pulling rear axle out.
Dec 29, 2009 at 8:54 AM
BILLYMAC
  • 2,204 POSTS
hi
remove bolts around diff cover.drain rear diff.
spin carrier to side where 8mm bolt isgoing through
remove this bolt .now pin will pull out.
now go to rear wheel push all the way in toward body.
remove c locks from axle at carrier.now pull axle out
bearing is pressed on axle shaft
Dec 30, 2009 at 10:20 AM
