Could head gaskets cause over heating?
DURDEN5
  • 1999 CHEVROLET SILVERADO
  • V8
  • 4WD
  • 212,000 MILES
Could head gaskets cause over heating, causing the water to overflow out the reservoir tank, after getting hot. We have checked everything else?
Wednesday, April 7th, 2010 AT 9:17 PM
Blown head gasket will cause it to overheat and other stuffs such as a cracked head or block and an intake manifold leak, thermostat stuck closed, radiator clogged and a defective water pump to include airlock.
Here are two guides to help us fix the issue.
https://www.2carpros.com/articles/engine-overheating-or-running-hot
and
Tuesday, June 1st, 2021 AT 6:15 PM
IMLEN2
Had to replace the thermostat cost $56.00
