1999 Chevy Silverado OIL PREASURE
180,000 MILES • V8 • 4WD • AUTOMATIC
EARNHARDT
I KNOW THE OIL PUMP NEEDS TO BE REPLACED. MY QUESTION IS WHEN REPLACING OIL PUMP ,I SHOULD CHANGE THE MAIN BEARINGS ALSO, CORRECT.
I'VE BEEN PULLING A 7X14 INCLOSED TRAILER ALL OVER THE U.S.. MY ENGINE IS A 5.3 V8. I JUST HAD THE TRANNY REBULT,ALSO. IS THIS ENGINE TO SMALL TO PULL THE LOAD OR IS IT THE ENGINE NEEDS A TOTAL REBUILD.
THANKS, JOHN
Mar 18, 2009 at 1:53 PM
BLACKOP555
  • 10,386 POSTS
chec, the bearings and see. while your there you can replace them. wouldnt hurt anythign!
that engine has plenty of power for pulling that trailer around.
Mar 18, 2009 at 2:12 PM
