1999 Chevy Silverado OBDII port doesnt work
113,000 MILES • V8 • 4WD • AUTOMATIC
RICHARDGBLACK
the check engine light came on in my truck, so I stopped at the local autozone to have them read the code, so I could acess what needed to be done. When it was plugged in and the key turned to run without starting the truck, the code reader wouldnt work. Some where there is a blown fuse, but I can't find it. I was also told that it's on the same fuse as the cigarette lighter, which also doesnt work, so I need to find out how to make the port work so I can read the code.
Jun 28, 2008 at 7:05 AM
RHALL77
  • 3,361 POSTS
check the fuses on the sides of the dash and under the hood
Jun 30, 2008 at 1:58 AM
