1999 Chevy Silverado Instrument panel lights are out.Truck
1999 CHEVROLET SILVERADO
16,000 MILES • V8 • 2WD • AUTOMATIC
RICK1971
Hi, I hope someone can help with this. I've had to reset the computer by taking out the ecm fuse and putting it back in several times over the last couple of weeks for my truck to start. Now that won't work anymore and my instrument panel lights aren't on and fuel pump isnt humming.
I've checked all fuses and relays and they all seem to be fine with the exception of the relays down by the steering column. Not sure what these are for but one of the small ones look like it may be bad.
Is it possible that the lead wire from the battery to the fuse box might be to corroded? I've had to change the wire from the battery to the starter because of this. The wire looks ok to me but cant see inside the shield to make sure.
Feb 10, 2009 at 3:07 PM
2CARPRO JACK
  • CERTIFIED EXPERT
  • 11,533 POSTS
When it wont start or the lights arent working, use a test light to see if you have power to the interior light fuse in the fuse panel, if not it may be an ignition switch problem
Feb 11, 2009 at 1:33 PM
RICK1971
Hi Jack, thanks for getting back to me. I believe its the ignition switch. Is there any tips I can get from you or a site that can show me the easiest way to change the switch? I've heard its not an easy thing to do.
Thanks
Rick
Feb 11, 2009 at 1:53 PM
2CARPRO JACK
  • CERTIFIED EXPERT
  • 11,533 POSTS
Is this an old or new body style? 99 was the transiition year
Feb 11, 2009 at 3:50 PM
RICK1971
old body style
Feb 11, 2009 at 6:20 PM
2CARPRO JACK
  • CERTIFIED EXPERT
  • 11,533 POSTS
Then the ignition switch is mounted on top of the column, about 3/4 of the way down to the firewall. You have to remove the hi-beam switch to unbolt it.The best way is to remove the panel under the dash.Once the panel is off, you will see a cable attached to the column, it is for the shift indicator.Unhook it. there are 2 15 mm nuts holding the column mounting plate to the dash support. When you remove them the column will lower down to make access easier.The switch is driven by a rod you will be able to see peeking up from the column when the old switch is removed.
Feb 11, 2009 at 8:07 PM
RICK1971
Hi thanks for the tips. I cant get the top trim off without removing the key tumbler to get to the screw for the ignition switch. How do you remove the tumbler? Ive been looking for a set pin but no luck
Feb 12, 2009 at 2:21 PM
2CARPRO JACK
  • CERTIFIED EXPERT
  • 11,533 POSTS
If this is an old body style (87-99) then the igniton switch (electric part) is where I described, nothing is up there but the key tumbler
Feb 12, 2009 at 2:39 PM
RICK1971
Got it fixed. It was the ignition switch. Thanks again for your time
Feb 12, 2009 at 6:51 PM
2CARPRO JACK
  • CERTIFIED EXPERT
  • 11,533 POSTS
My pleasure..........
Feb 12, 2009 at 8:49 PM
