1999 Chevy Silverado IAC motor
CHEVY166
1999 Chevy Silverado Two Wheel Drive Automatic 63000 miles
What tells the IAC motor what to do?
Jul 18, 2009 at 1:29 PM
  • 75,988 POSTS
https://images.2carpros.com/forum/automotive_pictures/12900_iac_idle_air_control_motor_1.jpg
How Does an Idle Air Control Valve Work? (IAC) An IAC (idle air control) motor is designed to adjust the engine idle RPM speed by opening and closing an air bypass passage inside the throttle body. The car computer or ECM (electronic control module) receives information from various sensors and will output signals to adjust the IAC motor in or out to adjust engine idle speed by controlling engine idle air. An IAC motor can fail one of two ways, either the motor short circuits and stops working or the motor will develop high resistance and cause the IAC control motor to react slowly, either failure will cause the engine to stall at idle. When a trouble code scan is performed it sometimes won't always detect a failed or weak IAC motor. To check the IAC motor remove the unit, with the wires connected turn the key to the "on" position without starting the engine, the IAC should move in or out. If the IAC motor does nothing it has probably failed, replace it with a new unit and recheck system. Note: while the IAC motor is removed clean (use aerosol carburetor cleaner) the passages the IAC uses to control idle air speed. Idle Air Control Valve (appearance will vary) Common Problems An IAC motor is highly susceptible to carbon and coking build up; if an IAC goes too long without cleaning it can cause stalling and poor idle quality. Some cars are designed with a large vacuum transfer hose that connects the intake manifold to the IAC (idle air control) motor. If a broken or dilapidated these vacuum lines can cause the engine to lose vacuum which will allow the engine to run rough and die. Inspect all engine and accessory vacuum lines to look for missing, torn or dilapidated lines and replace as needed. Any car that is designed with a magnetic non-motor operated IAC like Lexus is subject to carbon and should be cleaned about every 40,000 miles to avoid stalling. Basic Maintenance To check the IAC motor remove the unit, with the wires connected turn the key to the "on" position without starting the engine, the IAC should move in or out. If the IAC motor does nothing it has probably failed, replace it with a new unit and recheck system. Note: while the IAC motor is removed clean (use aerosol carburetor cleaner) the passages the IAC uses to control idle air speed
Jul 18, 2009 at 1:38 PM
CHEVY166
IAC motor seams to be working correctly. It's new so I moved the plungger in to less than 1 1/8. start the truck idles fine put it in drive as part of the procedure and it runs a few minutes and then goes back to the way it was before I changed out the motor. mass flow is good speed idle sensor is good. What causes the change?
Jul 18, 2009 at 1:49 PM
  • 75,988 POSTS
Test the MAF and TPS sensors.
Jul 18, 2009 at 2:04 PM
CHEVY166
Both are ok
Jul 18, 2009 at 2:19 PM
