1999 Chevy Silverado headlights
1999 CHEVROLET SILVERADO
167,800 MILES • 6 CYL • 2WD • MANUAL
RONJR72
For some time my headlights would flicker off and on when I left work in the morning. I know my lights are good because they are new. The brights work just fine but when I try to use the regular low beam, I get nothing. Im thinking its the relay that went out on me. Or would the automatic light switch that would cause this. I want to just know where is the relay located for that?
Jan 13, 2010 at 7:55 AM
JDL
  • 16,098 POSTS
Welcome to the forum, if you can't operate the low beams manually, I think the problem is either the dimmer switch or the wiring circuit to or from the dimmer.
Jan 13, 2010 at 8:19 AM
