1999 Chevy Silverado front end shake
47,000 MILES • V8 • 4WD • AUTOMATIC
RGADEN
intermitten front end shake, starts when braking after driving for awhile, then shakes at all speeds. Problem getting worse.
Sep 7, 2010 at 11:53 AM
DWB812
  • 108 POSTS
Hi rgaden,
Well, first, have you had any brake, suspension, or other front end work done recently? Is the 47,000 miles correct? That's low for a 99 so I thought it might be a misprint. Also, does the shaking get worse if you down shift and increase engine rpm suddenly? I also wonder if you are getting a brake induced pulsing that you are calling a shake or is it a hard shake?
Sep 19, 2010 at 1:24 PM
