1999 Chevy Silverado Driveshaft
197,000 MILES • V8 • 4WD • AUTOMATIC
RICHARD LOSCUTOFF
I replaced yhe U Joints and had problems getting the correct parts. When installing the driveshaft and tightening the straps and bolts at the pinion the U Joint caps just slip through. Help!!!!!
Dec 17, 2009 at 4:19 PM
  • 110,248 POSTS
If the caps slip through the u-bolt, you must have the wrong u-joint. Double check with the parts store.
Dec 18, 2009 at 1:48 AM
