[quote:ecc3d67613="Chevy 1500"]Interior problem
1999 Chevy Silverado V8 Four Wheel Drive Automatic 67000 miles
How can i get the doors off the truck when the hinges are welded solid to the truck and the door?[/quote:ecc3d67613]
If you look were the 2 meet in the center there is a pin that it pivots on. That is the Door Hinge Pin and you will need to drill them out in order to get the door off. You can order new door hinge pin repair kits from your local parts store.
Apr 4, 2009 at 2:39 PM
