1999 Chevy Silverado diagnostic codes
8,700 MILES • V8 • 4WD • AUTOMATIC
DAMMILLER1962
I have a check engine light on my 1999 Chev Silverado 4x4 6.0L... he has codes PO 171 sys too lean (bank1) and PO 174 sys too lean (bank2). What do I need to do?
Sep 18, 2009 at 7:59 AM
  • 75,988 POSTS
A lean fuel condition can be caused by:
* Low fuel pressure due to a weak pump or leaky fuel pressure regulator. (use a fuel pressure gauge to check fuel pressure at idle)
* Dirty fuel injectors. (try cleaning the injectors)
* Vacuum leaks at the intake manifold, vacuum hose connections or throttle body. (Use a vacuum gauge to check for low intake vacuum)
* Leaky EGR valve. (Check operation of EGR valve)
* Leaky PCV Valve or hose. (Check valve and hose connections)
* Dirty or defective Mass Airflow Sensor (MAF). (Try cleaning the MAF sensor wires or filament with aerosol electronics cleaner. Do NOT use anything else to clean the sensor, and do not touch the sensor wires)
Sep 18, 2009 at 8:01 AM
