1999 Chevy Silverado back windows
201,000 MILES • V8 • 4WD • AUTOMATIC
DANNO MANNO
I have a extendacab and the two push out back side windows are leaking air and noisey when driving. Is there a way to correct this easily?
Thanks Danno manno
Sep 19, 2009 at 12:01 AM
QUAGMIRE86
  • 98 POSTS
OK, silly question, but are the window "Lock cams" pushed into the locked position? If so, the rubber weather stripping is worn/deteriorated. You can either replace the weather stripping or you can try a thin strip of adhesive (house door) weather strip material on the contact surface(s)...any hardware store will carry that stuff.
My truck has wind noise but it is not from the rear windows, it is from the driver's side door. The door hinges will sag and allow wind to pass between the metal door skin and the rubber weather stripping material.
Sep 20, 2009 at 2:20 AM
