1999 Chevy Silverado
196,000 MILES • V8 • 4WD • AUTOMATIC
BOOGIE2506
when the truck is cold, it will crank rite up, after drove a bit, you have to crank on it 20-30 sec. then it will crank, has new filter, and pump, what can be done?
Aug 20, 2010 at 7:43 AM
  • 75,988 POSTS
Check the fuel pressure if its within specs if okay test the fuel pump relay and fuel pump and oil pressure sending unit
Aug 20, 2010 at 2:20 PM
