1999 Chevy Silverado
FULGHAMSTER
1999 Chevy Silverado Four Wheel Drive Automatic 92000 miles
when i turn the key it takes a few seconds to crank
Jan 28, 2010 at 3:12 AM
JDL
  • 16,098 POSTS
Welcome to the forum. If your saying no starter action for a few seconds, I'd have to check the circuits at the starter relay. Voltage to the load/switch side of relay is hot all the time. Voltage to the coil side of relay, comes from the ignition switch through the neutral switch. Have you tried cranking in neutral?
Jan 28, 2010 at 5:02 AM
