1999 Chevy Silverado
252,000 MILES • V8 • 2WD • AUTOMATIC
LILL2SHY
the gear indicator does not show at all, the transmission works fine and it shifts perfect, it just does not show what gear you are in. Is the cluster damaged?
May 12, 2008 at 8:25 AM
RHALL77
  • 3,361 POSTS
could be the cluster or the neutral safety switch. you will have to check it with a scan tool to see if the switch is reading correctly.
May 13, 2008 at 12:47 AM
