1999 Chevy Silverado
94,000 MILES • V8 • 4WD • AUTOMATIC
SILVERADO99
I had a new fuel pump installed. Before changing fuel pumps I was getting about 16 MPG. After the new fuel pump was installed, the gas mileage immediately dropped to about 11 MPG. Any suggestions or recommendations?
Mar 24, 2008 at 4:38 PM
DENNYP
  • 1,824 POSTS
Check for a leaking fuel pressur regulator.
Mar 26, 2008 at 9:11 AM
SILVERADO99
I had the fuel pressure regulator replaced about a month after the fuel pump was replaced. No change in MPG.
Mar 26, 2008 at 3:50 PM
DENNYP
  • 1,824 POSTS
what is the fuel pressure with the engine running?
Mar 27, 2008 at 1:37 AM
SILVERADO99
No problems with fuel pressure since replacing the regulator. I don't know what the fuel pressure reads or how to check it. But with the old regulator I had problems starting the engine. It would also occasionally die while running. No problems with the new regulator. Gas mileage has not been any better since the new regulator.
Mar 27, 2008 at 4:23 PM
