1998 Chevy Silverado Won' Start
168,000 MILES • V8 • 4WD • AUTOMATIC
MCCOLLUM40
Turck ran fine last week. Tried to start today and won't turn over. Battery is fine; engine tries to start but doesn't seem to be getting fuel. Fuel pump runs when key is turned on. Codes were cleared last week before getting emissions check. Did not pass emmissions because on-board computer was 'not ready' to read pollution control system. Drove home from emmissions inspection and truck now won't start.
Mar 13, 2010 at 4:44 AM
  • 75,988 POSTS
Hi mccollum40, Welcome to 2carpros and TY for the donation
Lets determine if its a fuel or spark issue
Cranks but no start condition:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
If both fuel and spark is present-check the valve and ignition timing, this will lead you to problems
with compression and valves opening and closing at the wrong time/broken or jumped timing
belt/chain.
Mar 13, 2010 at 5:30 AM
