1998 Chevy Silverado WHAT CAUSES WABBLES OR SHAKES?
188,200 MILES • V8 • 4WD • AUTOMATIC
DRUIZ1961
RECENTLY CHANGED MY SHOCKS,BRAKES,AND TIRES
EVERY SO OFTEN WHEN SLOWING DOWN SAY TO TURN IT SHAKES/VIBRATES ALOT WHAT COULD IT BE?
Apr 13, 2008 at 6:34 PM
  • 31,937 POSTS
Hi there,
If you can feel the brake pedal pulsating check the rotors for run out, otherwise, you will have to check all the steering and suspension components , something may be loose, check wheel bearings, engine mounts and sub frame mounting bolts.
Mark (mhpautos)
Apr 13, 2008 at 9:35 PM
