1998 Chevy Silverado rough running
JIMBO55
  • 1998 CHEVROLET SILVERADO
  • 6 CYL
  • 100,000 MILES
Truck starts to cut out at high speeds around 70 or going up hill, I changed fuel filter and replaced the cat converter?
Thursday, July 23rd, 2009 AT 5:24 PM
Dirty fuel injectors (cleaning the injectors often fixes this).
Bad MAP (manifold absolute pressure) sensor
Bad TPS (throttle position) sensor
Bad or dirty MAF (mass airflow) sensor
Low fuel pressure (leaky fuel pressure regulator or weak fuel pump)
Vacuum leaks (intake manifold, vacuum hoses, throttle body, EGR valve)
Bad gasoline (fuel contaminated with water or too much alcohol)
Sometimes, what feels like a hesitation is actually ignition misfire rather than lean misfire. The causes of ignition misfire may include:
Dirty or worn spark plugs
Bad plug wires
Weak ignition coil
Wet plug wires
Friday, July 24th, 2009 AT 1:09 AM
