1998 Chevy Silverado Removing vacuum booster
124,400 MILES • V8 • 4WD • AUTOMATIC
EJ494DOR
We are trying to remove the vacuum booster to replace it. We can't figure out how to disconnect the brake pedal from the booster arm inside the cab of the truck.
There is a little black clip on the right end of the shaft, but we can't figure out how to get that clip out. It is difficult to get to that clip with the mounting brackets and steering column right there too.
Is that even the right approach? Is there a special tool required to do this?
Thanks
EJ
Jun 7, 2008 at 7:08 AM
BDNWTKFG
I see you got no replies for over a month, so that tells me this is a B.S. site. . .
I am having the same issue with my 97 C3500 Crew Cab. I've spent 4 hours ^%&**&^ing with this miserable little stinking clip. . . ANY info you have would be greatly appreciated!
Email is BDNWTKFG@wans.net
Thanks, and I hope you got the info you were looking for!
David
Feb 22, 2021 at 10:16 AM
