1998 Chevy Silverado Rebuilt engine multiple or random misf
130,000 MILES • V8 • 4WD • AUTOMATIC
EVAN TYRRELL
1998 Chevy k1500 350 129000 miles
I recently rebuilt this engine and did all the mechanical work myself. I had a very experienced guy do the block work, and he put a new crank in it. I kept the same cam and heads. The mechanic that did the block said the cam was alright, and the heads/valves appeared alright to myself and several others. After several hassles and tinkering i am to the point where the engine will run but brings up the po300 trouble code, twice. I have been through the ignition system several times, and everything appears fine. I have no compression tester, and did the valves according to a haynes manual. What next? I am getting limited on what i can do myself and dont wanna go broke at the shop. Any suggestions????
Mar 5, 2010 at 2:17 AM
EVANTYRRELL
Other than the misfire codes i have been getting o2 sensor codes since before the rebuild. After the rebuild i got an additional code for the o2 heater sensor, I believe on bank one. Today i tried unhooking the map and maf sensor, It didnt seem to have any effect on the motor.
Mar 5, 2010 at 5:35 AM
EVAN TYRRELL
Parameter Description Value
DTC for which Freeze Frame was Stored P0300
Fuel System 1 Status Open Loop
Fuel System 2 Status Open Loop
Calculated LOAD Value 26.67 %
Engine Coolant Temp 80.60 °F
Short Term Fuel Trim - Bank 1 0.00 %
Long Term Fuel Trim - Bank 1 0.00 %
Short Term Fuel Trim - Bank 2 0.00 %
Long Term Fuel Trim - Bank 2 0.00 %
Intake Manifold Absolute Pressure 20.73 inHg
Engine RPM 2,544.50 rpm
Vehicle Speed Sensor 0.00 mph
Air Flow Rate Mass Air Flow Sensor 7.78 lb/min
Absolute Throttle Position 29.02 %
idk if this helps
Mar 5, 2010 at 7:36 AM
2 LINSEY
  • 287 POSTS
Hi, Thanks for using 2CarPros.com. I wanted to see where your at with your problem and see if was any additional information we could help you with. I f so please let us know, Thanks again.
Mar 12, 2010 at 8:33 AM
