1998 Chevy Silverado Rear Brake/Turn signal/Hazard inoperat
ANTINEOCON
Electrical problem
1998 Chevy Silverado V8 Two Wheel Drive Automatic 120k miles
Please help. I have checked fuses and relays. Have replaced 2 flashers under dash. No obvious wiring problem found and all grounds are in proper position.
High mount brake light works and front signals and flashers work.
Dec 9, 2009 at 10:10 AM
  • 110,246 POSTS
Follow the wiring from the rear lights. It will come to a plug in. Unplug the wiring and make sure there is no corrosion. Also, check at that point for power to the rear lights.
Let me know what you find.
Dec 11, 2009 at 12:14 AM
