1998 Chevy Silverado lights dimming when breaking
21,000 MILES • V8 • 4WD • AUTOMATIC
GENEGREGORY
when I step on the break the interior and dashboard lights dim. I have already cleaned battery cables with no success.
Jan 4, 2010 at 3:11 AM
JDL
  • 16,098 POSTS
Welcome to the forum, check the charging system. You can also do a voltage drop test. An example, Test headlamp voltage at the front end of circuit, then check at the headlamp itself.
Jan 4, 2010 at 3:31 AM
GENEGREGORY
found the problem. the the trailer hitch electrical connection was wet so it was shorting out the lights. dried it with a hair dryier and the problem went away. thanks for you help.
Jan 4, 2010 at 4:15 AM
