1998 Chevy Silverado Intake manifold
140,000 MILES • 6 CYL • 2WD • AUTOMATIC
RONNIEDUER
How hard is it to pull intake and replace gasket. What could cause gasket to fail?
Oct 20, 2008 at 10:29 PM
DOC762399
  • 8 POSTS
It's not hard to replace the gasket it's self or pulling the manifold. The real problem will be making sure you label all the stuff you have to remove, so you can get everything reinstalled right. as for the gasket being bad? Are you sure the gasket is bad? What are/is the problem?
Oct 21, 2008 at 12:02 AM
