1998 Chevy Silverado fuel problems
150,000 MILES • V8 • 2WD • AUTOMATIC
EL VATO MALO
I drive my truck with no problems, but if I drive it over 100 miles, it does not want to excellerate, like it does not have enough gas going to the engine, it kind of stalls. could it be the fuel pump? I took it to a shop and they can't find the problem, as they don't have the time to drive it 100 miles.
Nov 17, 2008 at 1:09 PM
  • 75,988 POSTS
Check the fuel pressure to rule out the fuel pump/fuel filter/pressure regulator-if the fuel system is okay
Check and test the TPS/MAF/MAP sensors
Nov 17, 2008 at 5:34 PM
