1998 Chevy Silverado Engine Misfire Code
70,000 MILES • V8 • 4WD • AUTOMATIC
GRYANJUDD
My check engine light came a about 3 months ago and i had the code checked and it said cylinder 5 was misfireing. I changed the spark plugs to the recomended plugs and changed fuel fliter due to the age of the truck. It still says same engine code. Cylinders 5 & 7 plugs are extremley coreoded and i have to clean them monthly, all other plugs are perfectly clean. After i replaced the fuel fliter i have started to shoot black soot out of the tail pipe. What do you think would be causing this? CO detector, piston rings? Anything would help
Jan 21, 2010 at 3:55 AM
DOCFIXIT
  • 18,828 POSTS
Check compression on 5-7
Jan 21, 2010 at 4:05 AM
GRYANJUDD
[quote:1bb99a76c0="Docfixit"]Check compression on 5-7[/quote:1bb99a76c0]
I have allready checked. 5 & & have 50lbs and the other have 118 if i remember right.
Jan 21, 2010 at 4:42 AM
DOCFIXIT
  • 18,828 POSTS
Well there is your answer should be @145+ 50psi is not going to ingnite and 118 barely.
Jan 21, 2010 at 5:17 AM
GRYANJUDD
so what is the first thing i should do to fix it?
Jan 21, 2010 at 5:41 AM
DOCFIXIT
  • 18,828 POSTS
A cylinder leak down test would tell if burnt valves or rings. Otherwise need to pull head check valve seats and valves for warpage.
Jan 21, 2010 at 5:50 AM
