1998 Chevy Silverado ENGINE DIAGNOSTIC CODES
177,000 MILES • V8 • 2WD • AUTOMATIC
TOMHAYES
I HAVE 2 CODES FOR MY TRUCK. THEY ARE:
P0420 AND P0430
Catalyst System Efficiency Below Threshold (Bank 1)
Catalyst System Efficiency Below Threshold (Bank2)
Can you tell me what needs to be done to correct these codes? I had a new Catalytic Converter installed 1 year ago. Thanks for your help.
Mar 8, 2008 at 11:54 AM
BLACKOP555
  • 10,386 POSTS
those codes are for bad cat's.
firrst thign to check is to see if the sensors are good, if they are bad replace them. also you may have a exhaust leak causing those codes to appear.
Mar 9, 2008 at 3:10 AM
