1998 Chevy Silverado cold truck
114,000 MILES • V8 • 4WD • AUTOMATIC
CHARLES001
the truck runs consistantly at 150 degrees I have put a 195 degree thermastat but hasn't helped at all
Feb 10, 2010 at 9:41 AM
  • 75,988 POSTS
Low heater output can also be caused by a thermostat stuck in the open position or the wrong temperature range thermostat. If the coolant temperature at the thermostat housing or radiator inlet is unusually low (140 degrees or less), the thermostat needs to be replaced. Also check if the heater core is clogged and aslo the heater control valve
Feb 10, 2010 at 10:20 AM
