booster
1998 CHEVROLET SILVERADO
149,000 MILES • V8 • 2WD • AUTOMATIC
RPN002
Why the brake pedal is to hard to step on and make like leaking air noise and the truck don't stop inmediately?
Sep 19, 2010 at 5:08 PM
  • 31,937 POSTS
Hi there,
Thank you for the donation,
This problem you have described is constant with a faulty brake power booster, this is vacuum operated and the noise you hear is vacuum leaking from the unit, vacuum is supplied via the inlet manifold on petrol engines and a dedicated vacuum pump if diesel, have the brake booster inspected for a fault. i would have this done ASAP.
mark (mhpautos)
Feb 22, 2021 at 10:16 AM
