At first my high beams quit working, then my cruse control, and now my brake lights. I've checked fuses and relays, and now I want to check the control arm switch on the colum. I'm almost certain I have to remove the air bag on the steering in order to get to the control arm switch so I can check to see if it is faulty. Although I've read in a Chilton repair manual how to remove the air bag on the steering wheel my set-up seems to be a little different or i'm doing something wrong and have yet been able to remove it. Can you explain or provide a pic to show me how to remove the air bag from the steering wheel, explain what I need to do to check to see if the control arm switch is faulty, and finaly explain the procedure for replacing the control switch arm. Thanks for your help.
Dec 21, 2009 at 2:51 PM
