1998 Chevy Silverado brake lights backward
1998 CHEVROLET SILVERADO
202,256 MILES • V8 • 4WD • AUTOMATIC
DASH142
problem with a 1998 chevysilverado 1500 series 4 wheel drive, brake lights stay on all the time, replaced brakelight switch and ignition switch but the brake lights sill stay on..and when stepping on brake peddle they go off, checked the relay switch under the hood and power is going to it all the time. pull the fuse under the hood and the brake lights go out..
when i put the fuse back in and i turn on the 4 way flashers they stop working until i step on the brakes then the 4 ways work..take my foot off then they stop working.. any ideas?
Apr 8, 2010 at 11:58 AM
BLUELIGHTNIN6
  • 16,542 POSTS
loose or faulty ground wiring. check ground at brake switch
Apr 8, 2010 at 12:53 PM
