1998 Chevy Silverado abs
DHUSCHA
  • 5 POSTS
Brakes problem
1998 Chevy Silverado V8 Four Wheel Drive Automatic
hello my name is dennis i think my abs went bad how do know if it is the abs my friend thinks it might be the drums how can i tell witch it is when i put car in gear car dont wont to move sometimes 1 tire will spin and the other wont move
Mar 16, 2010 at 7:04 AM
MMPRINCE4000
  • 8,548 POSTS
If ABS is the problem, then the ABS light will be on. If it is on, then you will have to have it scanned by a chassis scanner to get code.
If ABS light is not on, then it is most likely a mechanical problem, stuck shoe, broken return spring.
Mar 17, 2010 at 2:30 AM
