1998 Chevy Silverado
2FORJESUS
  • 1998 CHEVROLET SILVERADO
Interior problem
how doI repair/replace all parts that are used to open drivers side door and an illistration of such? I know I need to remove the door panel.
Monday, August 16th, 2010 AT 4:08 PM
WRENCHTECH
  • 20,761 POSTS
Can you be more specific? What exactly are you trying to change?
Monday, August 16th, 2010 AT 4:37 PM
2FORJESUS
Yes, the drivers side door will not open from inside using inside handle when the door is fully closen. If not fully closed (latched) then you can open the door from inside with the inside handle! When fully closed (latched) you have to roll the window down, reach out, open the door with the outside handle. How do I repair this problem, what parts need repairing/replaced and how do I get a picture (illastration(s) to how the parts are placed inside the door? Thank You for your help!
Monday, August 16th, 2010 AT 5:28 PM
WRENCHTECH
  • 20,761 POSTS
It sounds like a problem with the latch but it really needs to be inspected carefully to determine if that is really the case or not. The door does not have to be removed for any of this but the door panel has to be removed to access these things.
Monday, August 16th, 2010 AT 5:31 PM
2FORJESUS
Your answer did not do any thing to help me with what I asked. I allready new that the panel need to be remvoed. Please refund the $12.00 dollars I sent. Thanks for nothing. JESSE
Monday, August 16th, 2010 AT 5:55 PM
CARADIODOC
  • 34,366 POSTS
A little courtesy will get you to the answer you're looking for. We aren't psychic. That's why we have to ask questions to drag the information out of you. Not sure why you're being so secretive yet expecting a quality answer.
Caradiodoc
Monday, August 16th, 2010 AT 6:02 PM
THIS IS MIKE
  • 686 POSTS
Your donation has been refunded, I am sorry we could not help you this time.
Monday, August 16th, 2010 AT 11:09 PM
