1997 Chevy Silverado Wheel fell off last month, showing sig
170,000 MILES • V8 • 4WD • AUTOMATIC
SPCQUIGG
  • 5 POSTS
About two months ago my ABS light came on on my Chevy K1500. I went through the normal steps; changed the brakes checked the fluid check the caliper... Light was still on, decided to take to garage. On my way there my steering became erratic and my front passanger side wheel detached from the axel, the spindle was still attached to the wheel. I asked my mechanic if the bearing blew out, he could not tell. About 1500 dollars later the truck is back on the road. Now the ABS light is back on. Is the same problem going to occur, was it the wheel bearing, or is there an axel clip that might have fallen off?
May 19, 2008 at 11:30 PM
THE FACTORY MAN
  • 50 POSTS
Surely the guy who repaired it can tell you what failed and maybe why!!! Sounds like it MAY have been a ball joint? What you did to repair the ABS light isn't what causes an ABS light to come on. You may have a sensor or wiring issue. Get the trouble code that is stored and that will get you going in the right direction to repair it. Better yet, take it to a qualified tech.
May 20, 2008 at 8:43 AM
