1997 Chevy Silverado timing chain
EDWARD LILJEQUIST
Engine Mechanical problem
1997 Chevy Silverado V8 Two Wheel Drive Automatic
i have lined the two timing dots together and checked tdc ant it still whont crank im a beginer mechanic
Nov 30, 2008 at 4:22 AM
JAMES W.
  • 2,394 POSTS
Do you mean it won't start, or it won't crank over? If it turns over but won't start, check your spark and fuel pressure. Please advise.
Nov 30, 2008 at 7:34 AM
DOCFIXIT
  • 18,828 POSTS
Check to see if Crankshaft sensor is on properly and seated.
Nov 30, 2008 at 7:35 AM
EDWARD LILJEQUIST
The truck wont start. I was replacing the timing chain alined the dots and nothing.
Nov 30, 2008 at 7:42 AM
