1997 Chevy Silverado timing
JONGLENN352005
  • 1997 CHEVROLET SILVERADO
  • V8
  • 4WD
  • 190,000 MILES
I have a 5.7 vortec and I changed the head gaskets and put it all back the same way and I put one 1 piston up and the mark on the harmonic balancer lined up with the mark on the timing chain cover and put the distributor where its suppose to be lined up and every time I try and crank it dont start so I put the mark on the harmonis balancer back with the marks lined back up and the rotor button on the distributor ends up 180 out every time even if I correct it
Tuesday, August 18th, 2009 AT 1:31 PM
WINEBURGER
  • 82 POSTS
Bring motor top dead center commpresion. Line the rotor up where number 1 is inside the cap follow the lines across the cap. Snap throtle every time you move the dist to set te timming
Tuesday, August 18th, 2009 AT 1:54 PM
