1997 Chevy Silverado temperature to low
17,100 MILES • V8 • 2WD • AUTOMATIC
CHEVYZ
temp doesn't ever get above 150. When it's below 20 degrees and cold, water temp is around 120-130. Cab Heat is warm at best. The thermostat is new and functioning properly. I have 2/3 of the radiator facing covered with cardboard. The cap is cold after 20 minutes of x-way driving. Do you have any ideas.
Feb 21, 2010 at 9:01 AM
  • 110,248 POSTS
If the temp never heats, it has to be the thermostat. If it is closed, very little coolant circulates which causes the engine to heat up. When hot, then it opens and allows the coolant to flow and cool the engine. How have you checked the t-stat? Here is a how to if you want to try it.
http://www.2carpros.com/dia/test_thermostat.htm
Check it and let me know what you find.
Feb 22, 2010 at 12:54 AM
