1997 Chevy Silverado Starting Problems
15,000 MILES • V8 • 4WD • AUTOMATIC
SCOTT ARMSTRONG
The starter went out, replaced it now i have such a weak spark it wont start. Checked the coil pack, its fine, changed the ignition control module, same, changed the pick up coil(module) whatever, same thing. I have a good red top Optima battery, so enough voltage. I have 12 volts going the the coil but a very weak yellow spark coming out of the coil. Can anyone point me in the right direction next? The ECU
Dec 29, 2008 at 8:04 AM
BLACKOP555
  • 10,386 POSTS
ou to try another coil. your getting plenty of power. the other side should be getting a -12v pulse each time it fires, that way it charges the coil, then when the pulse leaves the magnetic field colapses and gives you one heck of a jolt.
Sep 2, 2020 at 10:55 AM
