can i blow out oil cooler lines if i put too much oil in my engine
Jan 28, 2008 at 3:01 AM
MERLIN2021
✓Experienced Mechanic
How much is too much? and did you already run the motor? Take the oil filter off if only over by a quart. Drain or replace it. If way over full, drain out in a clean bucket and refil to correct level.
