Can I blow out oil cooler lines if I put too much oil in my engine
Monday, January 28th, 2008 AT 11:01 AM
MERLIN2021
MECHANIC
How much is too much? And did you already run the motor? Take the oil filter off if only over by a quart. Drain or replace it. If way over full, drain out in a clean bucket and refil to correct level.
