1997 Chevy Silverado High presure switch
228,000 MILES • V8 • 2WD • AUTOMATIC
HOTFOOT501
the high presure switch keeps kicking the compresser off i think its because its geting to hot but im not sure
Jun 4, 2010 at 10:00 AM
FACTORYJACK
  • 4,159 POSTS
The high pressure switch on the back of the compressor? It is supposed to open at 440 psi, have you installed a gauge set to determine what the hi and low side pressures are. If it is getting to hot, the question is why? The fan should be capable of keeping airflow across the condenser, to keep the pressure within limits.
Jun 4, 2010 at 4:45 PM
